Water pump and housing are on, the pulleys are painted and ready.
View attachment 1075130 View attachment 1075131
I see a 73 & up style pump....
I thought about this again and it seemed odd. Me only driving about 400 miles from November 2015 until January of this year?I changed to Dakota Digital gauges in 2015 and even now, Ginger only reads 43511.
That is really sad...I haven't even driven that car 500 miles in 5 years!
I was thinking the same thing because I also need a drop base on the Coronet, and it still barely clears. I'm solving the issue by getting a 6 pak hood.The air cleaner seems to fit.
That must be because of the LOW deck of the 383.
I am using the Performer RPM on both cars and on Ginger, I had to have a dropped base made for the air cleaner to clear.
This seems very zen like. It brought a smile to my face because it reminded me of my friends older brother talking about playing pool. "You just need to hit the ball where it wants to go".1) if you replace the rail, all the way back to the torsion member, it is no longer compressed a bit rearward
2) mock up all front sheet meta (doors, fenders, hood, lower valence, grille and lights ) with a minimal amount of tack welds and screws holding your repair together
3) adjust your repair to achieve near perfect alignment..... "bring your repair (rail and inner fender) to the outer panels"
4) yes, fenders flex, but when bolted all the way around they get stiff and find a happy place
5) the hood aligned with the cowl will dictate the front being square..... hood stops on top of radiator support should be equal
6)the more you mock up, the easier it is.......... it all only fits one way
7)break it down and weld it up
yes.... everyone over thinks it
the outer metal dictates everything, starting with the doors and hood
the nice thing about collision work is, you can't really make it any worse....... and you'll be surprised how easily it all falls in line
you won't be happy paying someone else to have the fun
In essence what you are saying is the "whole" car is the jig. The doors, the fenders, the inner fenders, the hood, k frame, pretty much the doors plus the entire front of the car. I am going to re-read this again to find where you make a case for replacing both frame rails, inner fenders, shock towers and radiator support instead of just 1/2 i.e. one frame rail, inner fender, shock tower, and radiator support. Once again this is great information and I really appreciate it.yes...... just remember, the fenders, doors, and hood only want to be in one place. You set up the inner structure to meet them where they sit. KD was on his way to the frame shop, and never had to go
Ok. I read all that the first time but the jest of it didn't sink in entirely. I turns out the entire inner front clip of that 66 Coronet is completely rust free and available. That option is looking better and better. I also have a line on a 1968 Satellite front end and hood that could complete my jig. Once again thank you.post 174-186
Thats why it exists.. Helping motivate & inform other victims...get a straight, solid, front section....... start a build thread, and we can walk you through it ....... that's why we are all here!
sorry KD.......we borrowed your thread, and put it to good use
Thats why it exists.. Helping motivate & inform other victims...![]()
