BeepBeepRR
Well just got done loading up the block,crank, heads and the rods and pistons. Should have it back by the end of the week. Its getting hot tanked today and will get the rest of the machine work this week.
Karma, gotta luv it.Got some freebies today. Just for putting in a MSD ready to run distributor, coil and wires today. I scored all of this.
View attachment 565523 View attachment 565524 View attachment 565525 View attachment 565526 View attachment 565527 View attachment 565528
Yea I have decided to keep it. I have another 727 out ion my shed that is bad. But I can use the tail shaft from it to have the monsterhome trans as the main transmission for the 440 Im building. I heard the motor home trans are built similar to Hemi transmissions.Just went through this thread. First post you mentioned the motorhome transmission is basically junk. Do not throw it away. Motorhome transmissions often have the stronger 4 pinion planetary gear sets and 4 disc front and rear clutch packs. Only the short output shaft and tail housing are unusable in a car application. Plus, it is a big block case (front section that counts). Hope your build goes well. Keep up the good work.
Got some stuff done today, cleaned the block and installed all the pistons and crank. The cam should get installed in the next few days. Waiting on a cam bearing. Someone made a booboo. Hint it wasn't me. Anyhow this thing is looking sexy..
View attachment 580254 View attachment 580255 View attachment 580256 View attachment 580257 View attachment 580258 View attachment 580259 View attachment 580260
