Has anyone installed theirs upside down?
That's the plan for mine...Rather than having the ribs stick down mine would be facing up and the flat areas will be facing down.
I'm only using it on the scissor truss areas so I'll be able to do the install with no seams.
Planning on installing the 2x4 flat led light fixtures (7500 Lumen) under the steel.
R-38 above in the truss's.
It should make for a nice job when it's finished...
View attachment 904547 View attachment 904548
I don’t really think they would work all they well upside down. You would have to screw inside the ribs and you would probably leave a lot of gap between the panel and the insulation on the flats. Not to mention you would really need to space your electrical boxes out from the rafter.
