daytona kid
Anyone know where I can purchase some of these brackets, new? They bolt to the rear cross member brace and the rear of the rear frame rails. And what is the correct name for them?
I am welding the new rails on, letting the welder cool off now. Here is a pic of the splice on one side, just about finished, before grinding. I drilled 3/8" spot weld holes in the old "left on" rails at the splice to increase the strength as much as I could. I skipped from side to side welding a little on each side to help prevent warping.
Burning the midnight wire.:coffee2:
I actually put both sides on at the same time, as a "unit". Skipped from side to side with small welds to keep warping to minimum. I took the old ones off as a unit as well, as you can see in the pic in post #58. I welded temp angle iron braces on old and new so the alignment would be exact. After I welded a brace on the old ones, I cut off the shock mount cross member to reuse it. I laid the new rails splice ends to the cut ends of the old ones, then tack welded the shock mount and the trunk brace to the new ones. Then put the new "unit" in place and tapped them/it into place while checking many measurements I had from the old ones before I removed them, Height from floor, distance between, side distance to wall of shop, etc., etc.,. I used a plum bob to mark the floor, center of back end of rails and used also it with other floor marks to insure car did not move. "Too many measurements are almost enough". Then started finish welds.I'm guessing that you spot welded on both sides of the rail and then ran the full bead all around? Looks good, you'll have to show us the full picture when you get both of them on.
I have moved on to Rust Bullet. It's silver but is easily top coated and seems to bond better.
BIG TIME! I'm celebrating with a margarita right now.Great work....Looking real good kid. Feels good to get over that frame rail hurdle eh?
I'm sure you guys already have the scoop on this, but wanted just to circle the wagon about the prep of topcoating rust bullet. Be sure to rough it up with 220-300 or one of those 3M Scuff pads until it takes on a dull flat look. Besides that, make sure it's very well ventilated where you use it or you'll be surfing the magical tide for a ride to the unicorn kingdom with Jimmy, Janis and the Lizard King on your flying mushrooms......In other words, you'll be high as hell.
Thanks Prop. Now I know what to get that will hold up. Can you apply it then weld it up?
No I didn't have the scoop, BIG THNX for any info like that Prop and anyone else! Forgive my lack of info, Let me get a little more scoop,. Can the Rust Bullet fill small pits, grinding marks, etc.? Kinda like a paint on bondo? Do you brush it on or spray it? Where is the best place to get the Bullet? Can you weld with it on the area?
