I wondered who would catch that. Ol' eagle eyes Mo did.I expect you catch enough grief over that thing between your fingers, So I will keep quiet.............8-)........................MO
I don't think so, at least according to the listing I'm reading from Brewer's?Would it make a difference if a 904 or a 727 tranny?.......................MO
Indeed.
I wonder if I could ask a favor of anyone reading this who has a 66-69 automatic b-body to take a pic of their crossmember for me, PLEASE?
Heck yes, it would be nice if I could pick up one from a FBBO member.
Indeed.
Oh man, that's very kind of you!View attachment 408170 View attachment 408171
Yep. found it right where I thought it should be. Let me know if you want it and I'll get it boxed up and shipped out to you.
I can use the 1/2" outlet that's plugged off to the right of the hole in the pic by using a bushing for the temp sensor - but then, what do I do about the heater hose adapter?Google "big block heater hose routing" then click on images or Chrysler water pump housings.
Doesn't look like that sensor is going to work?
Put your heater hose nipple in that hole and other on bottom hole, the other plug looks like sender goes in it.As I await the arrival of the new Brewer's trans crossmember, I'm back to trying to figure out how to employ my temperature sensor for my aftermarket gauge.
Weird situation, at least for me. That threaded outlet you see open is actually 1/4" NPT!
Can't say as I've ever seen that outlet that small.
The previous owner had rigged a 1/4" pipe nipple in there, then literally glued a hacked off heater hose nipple on top of it (see previous pics on this thread). Oy.
I was lucky to get all that out of there and salvage the threads.
The temperature sensor wants a 3/8" outlet, like the lower heater hose outlet I have currently plugged off with the silver plug at the moment. That top plugged outlet is 1/2" looks like. I can't use the lower 3/8" hole because the pocket it sits in isn't deep enough for the probe to go all the way in.
The probe part of the sensor barely fits in the 1/4" hole but I obviously can't rig that up, unless I put a nipple and bell reducer on there - which the probe won't pass through.
I'm not going to be running heater hoses for now, but would like to be able to in the future.
What the heck was that 1/4" outlet for from the factory?
Can anyone post a pic of the factory heater outlet positions for comparison?
The stock sender is on the driver's side on my housings. 1/8" or 1/4" pipe. How does that sender seal? Looks like it needs something (an adapter) for the sender to seat on lip around top of sender. Then the fitting in pic screws in to seal it. Am I missing something?View attachment 408643
Brewer's goodies arrived just now. The crossmember has been straightened and given fresh paint. Looks great!
Clutch fork boot is indeed a Mopar factory part and is brand new.
Always feels like Christmas when the UPS folks arrive.![]()
Perfect!Here ya go Ed, don't remember where I got the adapter, but any plumbing/hardware store should be able to help. Plenty of places to get the "correct " nipples online if need be. I just took my battered ones down to the local NAPA and matched something close.
My setup is a MP aluminum housing & pump if that mattersView attachment 408647
Ya gotta go gold to find out.......You guys are killing me with all this "nipple" talk. LOL.
Thanks!Here ya go Ed, don't remember where I got the adapter, but any plumbing/hardware store should be able to help. Plenty of places to get the "correct " nipples online if need be. I just took my battered ones down to the local NAPA and matched something close.
The sender is the usual aftermarket deal, where I'm going to need that special type of brass bushing (it's beveled on the 3/8" side) for the sender to screw into and seal.The stock sender is on the driver's side on my housings. 1/8" or 1/4" pipe. How does that sender seal? Looks like it needs something (an adapter) for the sender to seat on lip around top of sender. Then the fitting in pic screws in to seal it. Am I missing something?
Nice to see you got the cross member, don't see trans mount? Is the cavalry coming to help?
