Jetted the Edelbrock single 4 bbl on the Hemi,no more off idle stumble. Pulled the driveshaft found a tight rear u-joint.Pulled it apart and it was smooth and well lubed.Put it back together and still didn't like how it was.Gonna replace it.Up in the air about pulling the 4.10's for 3.23's.
On the 63 project painted some engine brackets and blades of the clutch fan. Engine is done.
Fitting the radiator to see if I need to modify anything before putting the engine and trans in.Gonna be a daily driver.
