1967coronet440
Hey James, is that a max wedge intake?I'm going to just try and get her dialed in with the new upper half for this summer
View attachment 702872 View attachment 702873 View attachment 702874
i measured it today...driveline is 1 degree down and the yoke looks like 2 1/2 degrees down also(measured from the back of the dana 60) for a total of 3 1/2...thats with 4 degree shims already installed...whats my options to get it to around 5-7? leaf spring car..cut the pads?Easy, place the angle finder on the rear cover bolts. They're 90 degree to the yoke C/L. I've done it both ways. The angle is with-in .1 degree.
what about the spring alighnment bolt,,,when i was installing the shims,with the thicker units the stud was barly in contact with the perch's..8° shims are available from summit, plus many smaller than that. Search pinion angle shims, I think I saw 169 results.
i know cutting the pads is the way to go,done it before,easpeasially with the amount the angle needs to drop ,dana 60 feels like its as heavy as the motor....almost a good time to just install ladder bars/coil overs since i would only have to use a hole saw and put 4 holes into the 2x3 boxed back half frame rails...and torch off the pads..Either cut the pads or build a tapered lowering block. If you build a block you can taper cut one side to what ever degree you desire. Drill a hole slightly smaller than the diameter of the spring locating pin in the block. Press a pin (same length as the thickness of the block) in the block until it protrudes the same distance as the locating pin in the spring. Then open the hole in the bottom of the block big enough to slide over the spring locating pin. You may need longer U-bolts. 1/2" block won't lower it much. Or you may want to go thicker and lower it.
Thanks, I got confused because summit says for max wedge use 2893. I have victor max wedges on my stroker and I have the 2891 manifold, had me thinking I had the wrong intake.@67Coronet440, I can answer that, cause I have the same manifold. It's a max wedge port, dominator flange super victor.
I made an adaptor to be able to use my trusted 850dp until I can get a dominator to dial in.
No it's standered portHey James, is that a max wedge intake?
Wrong again, I guess! Wasn't the first time, won't be the last. I could have sworn I saw the same number on yours as mine . 2891 is max wedge.33 Imp it's not a mw intake it has standard ports
some body decided they wanted pro stock size tires on there b body...its been back halfed with leaf springs,and i added cal-tracs bars,dana 60 was custom sized to the wells...which measure 20 inches..and the 4.56 gears offset the large tires.it had 5.13's..at 65 mph , its taching 3100 rpm's going down the freeway..it scares the prious drivers when i blow by them at 75 down the freeway,,,has a vibration though at around 65+ and up mph?
I was looking into it last night and it says the 2893 is for the old iron MW heads.I did some research, now edelbrock says it's for standard or max wedge port. That is the intake edelbrock says works with their max wedge port victors .
They sure aren't as big as my old iron max heads.
thats where i am now at 3 1/2 down,,should i just run the cal-tracs tight to avoid any chance of nose up? cars smooth until about 65 then it starts..I don't think you want 5 - 7 degrees down for Cal Tracs. If I remember correctly, it's more like 1 - 3 degrees down.
Bryand
