Sweet that is just sweet.
Those are the 3 x 500 CFM "Direct Connection/Mopar Performance" mechanically actuated carbs I presume?A set of these will eliminate that lean tip in condition concern.
bio could you put them inside the air cleaner or do you take it off when racing. You can just make a plate like 33 did. Just a thoughtThanks @HEMI-ITIS
Dodge 330 pops in, drops a couple of great pix, and then disappearswhen I immediately ask about the valley pan rear hold down bracket that he mounted the solenoids to...
Anyway, yes! It is so stealthy I had to ask if that was a factory piece!
I only have the rectangular strip of metal there.
I wasn't really thinking about concealing the nitrous oxide system,
BUT
since I am going to be "picking up" some races at the track, at car shows, at Cruisin the Coast, and who knows where else, it would be nice and possibly profitable to be able to pop the hood for a quick "inspection" by a competitor and for them NOT to know it's on the spray!
Air cleaner and top have always been on.bio could you put them inside the air cleaner or do you take it off when racing. You can just make a plate like 33 did. Just a thought
Fabricated.Is that a fabricated valley pan "brace" that the solenoids are mounted to? Bought or home made?
THANKS! and
Aluminum of course??
The last picture was with a tunnel ram with the 2 plates.When I installed the blower I just left the N2O system on. Never hit the button with the blower and that was over 20 years ago. Now I need to intercool to get my IAT down and the thought that N2O will lower the temps over 100*.That would give me temps around 50 to 70*even in the heat of summerI'm so jealous to have a blower and some juice.
No, not in this case. Used what we had. And a few ounces wasn't going to matter.Aluminum of course??
