Every turn is .025"
			Yeah, I'm not a quick as I use to be... But even on my best day I'm not sure I could have fired the engine up then unbolted the flywheel....... Actually I'm quite sure I couldn't...
 Why the heck would a crank manufacturer make a crank out of spec for the specific application?
Did they think customers would always run an automatic behind their product?
I've had the 4.15 crank since 2004. I've only had this one flexplate on it and I'm sure I had to file it oversize. Maybe that is why THIS happened?Honestly I'm surprised the flex plate fit... They are normally a very close fit too....
The clutch master cylinder uses this remote reservoir:
View attachment 1054643 View attachment 1054644
It has a bracket that allows it to be mounted in a convenient place:
View attachment 1054645 View attachment 1054646
I disconnected the trans cooler lines and shift linkage, then the Bouchillon Kickdown cable. That has worked flawlessly for almost 20 years.
Now draining the ATF:
Any thought of selling your Bouchillon KD setup???
I measured 2 other cranks and came up with the same size as the flywheel holes. This 4.15 stroke Ching-Chong crank is the only one that measures larger.Do you have another crank/engine to measure for comparison?
I've got the same sandblaster. I've had it for 13 years and now it needs a new hose. I think I've found it at the local hardware store.To get the paint to stick, I need to rough up the surface. I could have taken the parts to a Bumper shop to have them DEchromed but who knows how long THAT would take? Plus...Who still does this in California? The only Chrome shop I know of is quite expensive.
I decided to sandblast the parts.
I have THIS pressure pot:
View attachment 1051000 View attachment 1051001 View attachment 1051002 View attachment 1051003
But the hose was blocked. Remember this topic?
https://www.forbbodiesonly.com/moparforum/threads/sandblaster-replacement-hose.209528/
He's been very clear all the parts removed from the red Charger are going on to his other Charger...
If he charges anywhere close to that he's ripping you off! I put a 440 crank in my lathe, indicated it and machined 4 throws to fit a 400 block in less then half an hour. Machining your flywheel will take more set up time then machining.I may have some luck. A shop that came recommended can do it on their lathe. The man says he can do it next week. I didn't even ask a price. If it is under $300, I will feel lucky.
