I might have to tackle this after reading this very good write up.
It's also the spacing of the tread grooves. Mostly they are unequal and random in size - this reduces drone on the highway. Hard to see if yours have different sizes.Generally, the lower the treadwear rating, the fewer the tread grooves. A slick would produce far less noise than an all season radial.
My tires have a rating of 100.
KD have you tried different tires to reduce "road" noise?
That's why they invented loud mufflers and stereos!Ah, the dreaded road noise!...
This is an irritation I have as well. In reality, the car rolls back almost nothing, but it is still annoying to have someone very close to your back bumper. Now, when I come to a stop on a hill and someone else is right behind me, I let my car roll backwards just a little bit as the other driver is stopping. I have found it keeps them further away most of the time...I've found that most drivers that line up behind me at stop lights don't even consider the possibility that this car might have a manual transmission and IF I'm on a hill, I might roll back a bit on take-off.
Hey Kern, someone posted pictures of your Charger at the Show. It's on FB. Looks great.
I think it would had been easier to have the adapter threaded, and the bolts going from inside the car into the engine compartment.The clutch master cylinder is a Wilwood unit with an adapter to fit the Mopar floor.
View attachment 1054610 View attachment 1054611 View attachment 1054612
It would be great to just place it against the firewall and drill. This not possible with the engine in place and those two right side holes are right up against the wheelwell anyway.
Oh, the lower left bolt?
Trapped under the body of the master cylinder. You can't just set it against the firewall. You have to remove the adapter and separate the two, then get the bolt out.
I attached the clutch pushrod....
View attachment 1054614 View attachment 1054615
I must just be a lucky guy.Might want to take a quick check of your pinion angle after raising the trans up. Could save you some drivetrain issues down the road, especially if you ever decide to romp on it pretty hard and leave the drive shaft laying in the road.
Ha ha...Funny how time can change our minds, right Rich?Great thread Greg and thanks for taking the time to document the process. I may never get up the gumption to swap trannys in the Coronet but I've gained a better understanding of how the Dart is set up.
