- 12:35 AM
- Apr 13, 2012
- Granite Bay CA
Next up was the steering column.
I sure don't know everything but isn't there supposed to be a bearing here....?
This is the original column to this car but I have had it out and apart before. The first time was back in 2001 when the ignition switch shorted out. I must have disassembled it and forgot to but the bearing back in.
I found a spare in my stash and put it in.
This column will likely end up in my other car since I plan to do a Cordoba tilt wheel column in sometime soon. I didn't have all the parts to attach this bearing so I just added a few small tack welds to hold it in place.
I drilled the hole and screwed in the Zerk....
The hole is at the very end of the coupler...
The installation was unbelievably easy with the header out, engine lifted and torsion bar slid back.
