- 9:09 AM
- Apr 13, 2012
- Granite Bay CA
The clutch disc and pressure plate were installed. The bolts were torqued in a criss cross pattern and to spec. The disc only fits one way. With it the wrong way, the hub hits the flywheel bolts and the disc won't sit flat against the flywheel face. There were no stickers on the disc like I've seen before, maybe because in this case, proper fitment was obvious.
