I built a 68 (?) VW (it was VW bug in body only) with a 2x3" frame
377cid SBC w/front drive distributor, th350 upfront
& a 9" Ford rear/Ladders & coil overs rear,
Did the wider fiberglass fenders,
& a lil' bump in the rear of the hood, just under the winshield
to clear the carb/air cleaner, damn near under the dash
firewall set back some 10"s IIRC
I louvered the crap out of the hood (Bob Monroe did) & it still got hot
sat 'damn near' sitting 3/4s of the way to the rear end
just behind the B pillars, rear of an engine doghouse like a van inside
sit where just in front of where the org. rear seat would have been
2 Pro-car buckets, no back seat obviously, some serious engine setback,
had like (IIRC) 10"-12" driveshaft & it had nice polished kidney slots 8s & 10s...
Just a mild-built motor, bunch of extra parts, or old race parts laying around
just a street car, shockingly it really was an easy build...
Just dropped the floor pan out, started from scratch, cut out the rear inner fenders
front firewall & tank & org. sheet metal in the engine bay,
cell over the rear where the engine was
Alston steel tubs, sat really low, and looked pretty damn cool IMO
I also did a SBC 377cid/400 block-350 crank & th350 in a 66 Corvair Corsa same deal,
ill handling lil' bugger,
a lil' longer WB than the bug was too
back end (9" Ford on ladders/coil overs) it wanted to swap places/ends too much
mini tubbed, with 295/50/15 rears Rad. TA street tires, like 225/60/15 front
It ran 11.0s (118-120-ish IIRC) on 28x9 slicks, w/2800-3000 B&M Holeshot converter
I made (or attempted) it look like a mini 66-67 Chevelle 396 SS
had the hood bulges & all, I cut down a grill for the front, Scirocco rad
all electric pumps & fans (just like above) late 70's early 80s stuff
sat on a 2x3" frame w/Mustang 2 front parts suspension, parts from Alston Engineering
a Good buddy of mine Rob D. from Concord Ca.
had a nice 70 Datsun 510 with a 468cid BBC PG 9"
stretched the front fenders 4"s
it was fast a hell, low 9s high 8s, mechanical FI Hilborn 8 stacks
It ran with a BarryGrant electric pump, reg. mech nozzles too, on gas, sort of 1 off deal...
He also built a 48 (?) Morris Minor Coupe with a turbo'd 231cid 60* v6 4 speed
when he ramped up the boost, that thing was a riot...
I als had the obligatory multiple SBC & BBC/glide V8 Vegas too...
dang I can't find the photos, need to look in the slides
