ckessel
Mark the correct surgery area with a felt pen, in case the "experts" get confused. Be sure they don't take your plumbing so it can go to Rosie O'Donnel or another disgruntled non man.
I had that done a couple years ago, walked in a boot several months, but after it healed I was able to walk again without pain, even went on some wilderness canoe trips and portaging with a heavy pack and all was good. Main thing is that you stay off of it, the bones have to heel at just the right angle so you can walk properly. Only small issue I had was the big toe rubbed a blister on the toe next to it, as the big toe is now slightly shorter and bent a little over.Well it's here, going in this early AM to Des Moines for my big toe joint fusion.
Bad part is the no weight on that foot for a few weeks,
Glad I am getting it done, the cortisone injections only last a couple months at this point.
Wonder if they use torx or Phillips lol , I will have to ask.
Catch you guys later.
Same thing I had Edward , hallux rigidus stage 4 , unfortunately my arthritis had grown down to the bottom of the joint also. I did the shots for aprox 3 yrs.im having problems with ( hallux rigidus) they want to put a plastic piece in between joint, its not as severe as yours, but 6 weeks in a boot ! and its my right foot, no driving !! going for a shot tomorrow. keep us posted, ed
Thank you. That is encouraging news.I had that done a couple years ago, walked in a boot several months, but after it healed I was able to walk again without pain, even went on some wilderness canoe trips and portaging with a heavy pack and all was good. Main thing is that you stay off of it, the bones have to heel at just the right angle so you can walk properly. Only small issue I had was the big toe rubbed a blister on the toe next to it, as the big toe is now slightly shorter and bent a little over.
If you have a console, you could take it out put your right foot over the tunnel and use your left foot. Or instal a left foot feed I have seen both done successfully. If you don’t have a console you are a step ahead. Worked with a WW11 vet that was a tank commander that lost his right leg above the knee, and drove with his left foot until he passed away in his 80’s.im having problems with ( hallux rigidus) they want to put a plastic piece in between joint, its not as severe as yours, but 6 weeks in a boot ! and its my right foot, no driving !! going for a shot tomorrow. keep us posted, ed
I hear ya, every action has a.....Problems you may
encounter....(both of
mine are fused, (due to
frostbite/accident).
Hiking/climbing on any
type of an incline.
Cold weather, type of
shoes/boots, even
trimming your roenails
may become bothersome
as you're not able to change
the angle of cutting.
Also, what types of socks
you wear will affect the
pressures applied to the
ends of the toenails.
Ingrown toenails may
become problematic.
And, of course, running
for your life is used
figuratively.
Not trying to be a Debbie
Downer here.
I have different extremity issues, but I bought a set of cheap portable hand controls for around $100 I use on long trips in my daily driver, after my wife found out I was switching feet, or using a crutch tip. I have a premium, permanent set installed in the GTX. Much pricier, but has the advantage of driving with either the pedals or the hand lever, with seamless transition.If you have a console, you could take it out put your right foot over the tunnel and use your left foot. Or instal a left foot feed I have seen both done successfully. If you don’t have a console you are a step ahead. Worked with a WW11 vet that was a tank commander that lost his right leg above the knee, and drove with his left foot until he passed away in his 80’s.
How do you keep that sweet GTX floor mat so pristine? Mine looked nice – then they didn’t.I have different extremity issues, but I bought a set of cheap portable hand controls for around $100 I use on long trips in my daily driver, after my wife found out I was switching feet, or using a crutch tip. I have a premium, permanent set installed in the GTX. Much pricier, but has the advantage of driving with either the pedals or the hand lever, with seamless transition.
I have a trick. I swap it with one from my Lexus when I'm actually driving the car.How do you keep that sweet GTX floor mat so pristine? Mine looked nice – then they didn’t.
Make sure you get a circular incision, not a circumcision.Mark the correct surgery area with a felt pen, in case the "experts" get confused. Be sure they don't take your plumbing so it can go to Rosie O'Donnel or another disgruntled non man.![]()
Hope all turns out well. I’m scheduled for the 18th for a left thumb and wrist repairWell it's here, going in this early AM to Des Moines for my big toe joint fusion.
