Belvedere408
- 10:47 AM
- Jan 25, 2023
- Springfield Oregon
No slop in my borgeson box got from summit racing, no coupler.
None at all. I have no drawbacks to report with this steering unit.Did you run into any noise issues running up the column with that coupler?
Just to add on.. i am running the same box and same coupler, no weird noises at all. I had read stories from people that had noise but i got lucky..Did you run into any noise issues running up the column with that coupler?
Another term used is "High Point" Count the turns full right to full left divide 1/2 and you have On Center/High Point."On Center"
Both methods are good but the in/lb torque method is more accurate..One article in Moar Action displayed how to find the center using a torque wrench. The highest reading was found at the center. It sure seems easier just to spin full right then full left and divide the turns by 2 to find half/center.
How many miles after install when you started noticing increased belt squeal? Mine is fairly new and I'm not looking forward to that happening...I have noticed increased pump belt squeal too. It doesn’t reduce engine speed with me. Maybe if I had a stock 318 it might?
The squeal is annoying. I have a rebuilt Saginaw pump.
My experience as well. My belt is tighter than I'd normally like, but if it stops the belt squeal, I'll take the tradeoffThe trip to Van Nuys few weeks back.
I had Rich pull on the bracket as I tightened it. The belt was tight.
Either the pump is not up to the task, the belt slips despite adequate tension or the Borgeson unit just needs greater pressure. I don’t know where the problem lies just yet.
What part of the box is welded? I don't have pics of mine, but I just purchased/installed it last month.Which generation of Borgeson box is making the noise? There’s one that’s welded and one that’s newer that’s not welded.
My friend‘s dad bought the older version when they first came out. Noticed the mounting bracket one has a rounded bracket compared to the square bracket. He’s not getting any noise or hiss from his.They both look welded just like Greg’s above.What part of the box is welded? I don't have pics of mine, but I just purchased/installed it last month.
Mine is just like Greg's.My friend‘s dad bought the older version when they first came out. Noticed the mounting bracket one has a rounded bracket compared to the square bracket. He’s not getting any noise or hiss from his.They both look welded just like Greg’s above.
Ive ran the old box and ive got a 24 box also. My old box hissed like a snake and leaked oil. I replaced the old box and pump last year and its alot quiter than the old one. Ive never experienced any belt squeal with either one. Anyone with extreme hissing ive been told wrapping the column with like the leather baseball bat grips will quiet it down. IDK.My friend‘s dad bought the older version when they first came out. Noticed the mounting bracket one has a rounded bracket compared to the square bracket. He’s not getting any noise or hiss from his.They both look welded just like Greg’s above.
View attachment 1856003View attachment 1856004
