- 11:21 PM
- Mar 28, 2014
- South Louisiana
COMP Cams Endure-X roller lifters set the standards for solid roller lifter technology. Designed with oiling and inboard link bars, they are engineered to withstand the demands of aggressive cam lobe designs and increased RPM ranges. Featuring a wear resistant tool steel axle, precision sorted needle bearings, and EDM Oil Injection technology that guarantees the bearing assembly receives a constant flow of oil. Endure-X Solid Roller Lifters are heat treated, machined to ultra-high tolerances, and fully rebuildableComp 848 lifters
I went with CompCams hydraulic FT lifters, springs, locks, and retainers when I had to replace the lifters and springs on my current mill. Valvoline VR1 oil since I brought the car home. The CompCams parts have performed fantastic, and I also went with CompCams hydraulic roller cam and lifters for the 421 in the GTO, with zero problems.
The main reason for my insistence on solid lifters for my 541 stroker build is Jim Laroy's absolute insistence upon no hydraulic rollers, which came after the 421 build. Jim has his reasons, and as tempting as hydraulic rollers are, I can't defy Jim Laroy's advice, and if I did, and had a problem because of that, I'd sure be ashamed of myself for having been warned.
@IQ52 can you add anything to this thread? Refresh us all on why you warn against hydraulic roller lifters and what have you seen in a durable, low maintenance, reliable roller lifter?
