Any holiday discount code for FBBO members? Should I order through you direct or through the website?About 3 years now
Our coupler length is based on the EXACT length difference between the Borgeson box and the OE power box. This is a constant. Even with slight differences in coupler body lengths, this is never an issue. #67 seems to refer to getting an alignment after the box install. Since it's impossible to replace one casting with another exactly, you must at least check the toe before driving after the box is installed.Can anyone (esp Bergman) comment on KD's length install issue from post #67? Has anyone else had this issue when using the Bergman coupler that I plan to use? Mine is a '68 B body with collapsible stock steering column. (KD - I hope it's ok we keep your thread going with these questions...)
The small sector was 1972 and older cars and C body models.how do I know if I need the small sector box or the large sector box?
Small sector until 72. Large, 73 later.The small sector was 1972 and older cars and C body models.
Regarding the length of the steering shaft, I simply figured that the plastic shear pins just got old and brittle and did break, allowing the shaft to compress slightly.
my stock coupler has a round hollow metal roll pin (also called shear pin). Are we talking about the same thing? Or do you mean for the collapsible steering shafts some other internal pins?I thought that I read that Rick Ehrenberg referred to them as "shear pins".
This is what I thought. During assembly from the factory, the slip shaft needed to be held in place. The nylon accomplished this. When properly installed, the tiny anti pullout pin on the side of the coupler and the snap ring and e clip retained the shaft at either end for safety.The term that I referenced is not related to the coupler. The shaft within a shaft is where I am referring.
Did you have power steering prior to getting the borgeson steering box? I have manual steering, and would hate to cut the shaft, or swap in a power steering column to do this swap. I will if i have too though. My car is a 1967 b body. Don't know if i would have to swap the idler, and pitman arms.Yes, here goes!
This car is getting a Borgeson steering box. I ordered it last week and it arrived yesterday.
I expected a bigger box.
Well packed.
The shipper would have to be a real monkey to damage this.
Jeez, this thing is tiny.
View attachment 1289129 View attachment 1289127
FBBO vendor and site supporter Bergmanautocraft.com has been selling bolt in kits for 9 years. Power or manual, no shaft mods necessary. All collapsing column shafts were designed to accept power and manual. Our kits use OE hoses. If you have power already, simply plug in your original hoses. If you have manual, we have a complete conversion using factory style parts.Did you have power steering prior to getting the borgeson steering box? I have manual steering, and would hate to cut the shaft, or swap in a power steering column to do this swap. I will if i have too though. My car is a 1967 b body. Don't know if i would have to swap the idler, and pitman arms.
I do have manual steering. What would a complete conversion cost ? Thanks.FBBO vendor and site supporter Bergmanautocraft.com has been selling bolt in kits for 9 years. Power or manual, no shaft mods necessary. All collapsing column shafts were designed to accept power and manual. Our kits use OE hoses. If you have power already, simply plug in your original hoses. If you have manual, we have a complete conversion using factory style parts.
