BAC STEERING BOX UPGRADE MASTER KIT - Bergman Auto Craft Free shipping on this one (over 1,000) and no tax since we're a small volume business.
Cool. A friend of mine has installed a few of those now....much lighter weight and more compact than the standard power steering units.Yes, here goes!
This car is getting a Borgeson steering box. I ordered it last week and it arrived yesterday.
I expected a bigger box.
Well packed.
The shipper would have to be a real monkey to damage this.
Jeez, this thing is tiny.
View attachment 1289129 View attachment 1289127
Yep, i am also using the Saginaw pump and all is good, make sure you use the right power steering oil as recommended.I can attest that the Saginaw steering pump works well with the Borgeson unit. No unusual noises, no bad habits.
which ps fluid are you using? i read that Redline synthetic doesn't match up well with this due to foaming.Yep, i am also using the Saginaw pump and all is good, make sure you use the right power steering oil as recommended.
I prefer to stay away from any transmission fluid.I am using a Dexron II type oil, Borgeson mentioned it can be uses also.
I believe it is mainly the GM style power steering oils that is best for this setup.
Any chance of a discount code for Jan on this? Im thinking of jumping on a steering box.Yes. this is the basic kit and bolts in for guys with power steering already BAC STEERING BOX CONVERSION KIT - SMALL SECTOR 62-72 - Bergman Auto Craft
Well, that makes sense. I will heed that advice. Thank you Mike!
As I mentioned, I've had the column out of the car a few times. In doing so, I must have lost the foam seal that goes here:
Reproductions are available but going into a 4 day weekend means that I wouldn't get it for well over a week or more. I made one out of some 3/16" foam sheet I had in the attic. I suspect that this will in some small way aid in the reduction of road noise and such. Last month I went on a 900 mile car show road trip and although there were no breakdowns, the road noise at freeway speeds was something I've wanted to reduce.
