HAHNAGON
- 8:57 PM
- Jun 26, 2023
- MOUNT VERNON, IN 47620
Did Borgeson or BAC ever say anything about the use of fast ratio pitman or idler arms? Are they compatible with the borgeson setup? Are they not recommended or cause any issues? I installed a new borgeson gear box, hoses and coupler with a new saginaw pump. I also installed new pst tie rods, solid sleeves and fast ratio pitman and idler arms. I have some mild issues. I used mopar +4 ps fluid, NOT ATF+4 by the way. My steering still feels overboosted. Steering wheel moves very easy and has a very tiny bit of slop but not as bad as a factory ps gear box, but it's not what I expected. It also is glitchy like it doesn't have enough boost or air in the system??? I don't know. Its just not what I expected. I removed all zerk fittings and replaced the fast ratio idler arm with a standard idler arm because of clearance issues. I left the f.r. pitman on and nothing changed.
Any advice or noticeable issues with my combination. I have no problem swapping the fast ratio arms out for standard arms if that will solve my concerns.
I triple checked torque spec on everything, bleed the system twice, checked level when warm and cold, etc.
